14.9 volts at idle and load
Banzaiii67
2:07 AM
Milwaukie, Oregon
To summarize: I recently burned the fuseable link due to what I believe was a faulty solid state voltage regulator.
The fix: I replaced the voltage regulator with a standard motor product solid state regulator, and in addition I ran 8ga wire to the starter relay, then off the starter relay I ran more 8ga to a 60 amp maxi fuse which is 6" before the positive terminal, then obviously connected to the postive post. I used dielectric grease at every new connection.
Today I fired it up with a fully charged battery (it read 12.7v after a 2 day tickle charge) and took a reading with a reliable newish multimeter and it read a rock steady 14.9 at idle and without a load and dropped to 14.8 with a load. With increased rpms the voltage when unchanged.
Everything tell me that's too much voltage.
The alternator was tested at napa, and passed. It was off a c body with dual pulleys, I believe it to be a rated 60amp alternator but definitely is not new, nor rebuilt.
I did not run a ground from the alternator body to a voltage regulator bolt , I did however scuff the paint to bare metal around the mounting holes for the voltage regulator. Do I need to add a ground wire?
I did measure on top of the battery post with the multimeter, not sure if it matters that much if it's measured at the post or between the terminal.
Any ideas on next steps?
Working fine. If you check a manual, it can be as high as 15.2v depending on the temp.
The regulator is seeing a low voltage
You need to clean and tighten all connections to and from ignition switch as that voltage is ok at -20f not 70f
Steady 14.7 sounds just fine. Be sure to have a real good ground on the voltage regulator case, a separate ground wire may work well.
Mine runs a constant 14.5-14.7 and Ive never had issues. Better than the high 11's it was pulling before the 1 wire swap!
Please explain. That voltage seems about right to me, but maybe you've got more/better information?
That voltage is ok if the temperature is cold or for a short time after start up but long term will shorten the life of the battery in hot weather
Check voltage at regulator and you will see the difference and the cause
I had this exact same issue after cleaning and replacing lots of wire. I also replaced the alternator and voltage regulator twice. The fix for me was an adjustable voltage regulator (I found it online but don't recall the brand name) and have not had a problem since. It seems to me the cheap parts store regulators were out of spec causing my issues.
On a round back alternator, should a ground wire be hooked up, to the ground terminal?
And, does it make any difference, where the ground to body, is made?
