14 inch trim rings
plowman
4:06 AM
michigan
I see summit makes a 14 inch trim ring in brushed finish. I didn't think anyone reproduced in brushed finish in a 14 inch.
Thats good to know. For a long time there were no 14 inch brushed trim rings. About the only option was to take a chrome ring and turn it in a lathe and scuff it with an adobe pad or something similar.
I looked again and they had a N/A in red so I guess not
New Polished & Brushed Chrysler Ralley wheel 14 x 6 trim rings – New Reproductions. Please note – the contour of the ring is not the same as originals. The originals were flat on the outside lip – these are as well with a slight raised section on the lip. Close but not exact – closest to originals on the market.
320-37728 Individual Trim Ring – Brushed $ 69 ea
328-37729 Set of (4) – Brushed trim rings $ 269 set
http://www.laysons.com/
Aren't those stainless the originals aluminum
The repos we offer are brushed stainless. No one is making any aluminum trim rings thesedays.
The originals were stainless with a polished lip. 1969 was a one year only trim ring that had the inner lip and was 14 x 5.5 and attached to the outside edge of the rim like a wheel weight. Starting in 1970, they changed to the inner mounting point and was all the way around the trim ring. It also lost the inner lip.
Rick,
How does the trim rings attach to the rim? Are they 4 clips like the originals or are they like the 70 version that mount all the way around the inner part of the rim?
The mounting tangs go all the way around the inside of the rim. They fit VERY snug and will not come off easily if you hit a bump in the road.
