15X5 or 5 1/2 steelies question
dartforforty
Deceased, But not forgotton
Legendary Member (RIP)
11:19 PM
south jersey
are these a rare wheel? got a set on the front of my Coronet which are supposed to be a factory wheel, not for this car though
kind of... need to see a pic of the centers... the PN stamped on the inside between the beads would tell me for sure... looks like I might be buying something from you this time... :grin:
still have tires mounted on them. and they are on my Coronet. They do have dog dish hub caps on them. not a good pic
found the pay pal receipt in the folder of papers that came with the car, it reads 62-65 15X5 1/2 b-body wheel
Look to be correct large center with 63/64 caps. As long as the caps are retained by the nubs and not epoxied/rigged in some fashion those wheels are keepers (or sellers). They should have 5 lug holes and 1 locating hole between 2 lug holes. Locating hole should be aligned with the centerline of the hub and valve stem hole.
They likely are the correct K wheels.
so if they are legit,, what are they worth. I'll know if they are the real deal when I pop off the hub cap
Used to be worth good money especially if you already had them widened to 15x8. A vendor on moparts sells them blasted and trued for $600/4 for std. 15x5. Don't know if he sells many at that price.
I have several sets laying around and I wouldn't go less than $100/ea. It takes a lot of 'yarding and scrounging to find them these days. If your thinking you want to give them away, let me know.:toothy12::toothy12::toothy12:
won't be giving them away any time soon. I'll hold onto them for now. forgot to mention they look like they were powder coated
