69RRGTX
Hi,
This is probably a long shot, but I have an 18 Spline Hemi Box trans that I would like to sell. Was in my dad's shop or mine for the last 20 years. Needs a new home.
Here is what I know:
Mechanically complete
Turning the inputshaft by hand you can "go through the gears" seems to function as it should.
It is missing a couple of the bolts for the side plate/cover.
Has casting # C99129 on the main case and uses the 3.125" Dia #307 Bearing
Short 12.5" Extension housing.
4.354" Dia bearing retainer with an adapter ring to go to 4.807" Dia
Shifter is included, it would probably function fine if gone through, but I have no idea what year/body style it should / would fit. If I were to run it I would use an in-line shifter. FWIW
PM me if interested.
At a minimum this trans needs to be sealed up before being run.
650.00 + freight
Thanks,
Mark
650.00 + freight
Thanks,
Mark
