1964 2 dr post sedan door panels "Wanted"
Good luck it took me a year to find them. It's worth noting 2 door hardtops are the same for the doors. Rears from a 64 Plymouth will work but a 1" shorter in length but the rear seat hides the difference & there's a guy in CA repopping rears in fiberglass that you can't tell the difference once covered.
hope this helps.
Billy
I have a set out of a 65 Belvedere 2dr. sedan for sale,the metal upper frame is the same.
panel length
funnycar65
Rear 2 dr sdn Dodge panels are longer because of the wheelbase.
63-64 Dodge has a 119" wheelbase
65 Dodge has a 117" wheelbase
63-65 Plymouth has a 116" wheelbase
The front 2 dr sdn sdn panel steel are all the same 63-65 Dodge or Plymouth
I have 63-64 Dodge rear panels and they are longer than the Plymouth panels.
I have both 63-64 Dodge and 65 Plymouth steel parts front and rear.
The only rear steel I am not sure of is the 65 Dodge,is it the same as Plymouth?
Being that the 65 Dodges wheelbase is about the same as the 63-65 Plymouth.
Hope this will help
Jeff
so the the quarter window glass is longer in a 64 Dodge then a 64/65 Plymouth 2dr sedan?
So as I stated the upper metal frames are all the same be it Dodge or Plymouth!I never referred to the cardboard portion at all!
