FOR SALE 1964 426 wedge NOS block,24066730
jim picanzo
7:18 PM
mass
never assembled nos block.no stamping over counter block.2000.00
20200605_132200[1].jpg 20200605_132349[1].jpg 20200605_132207[1].jpg 20200605_132703[1].jpg 20200605_132355[1].jpg 20200605_134128[1].jpg
What are we looking at here? I see two pics of two different stamping pads, one is blank...
The pic with the cylinder bores is the same one you posted in your 440 ad...
why does the second picture show a v 42 stamp which is 64 426 st wedge?
426 Street wedge just like mine same year too 1964. Mine has matching 516 heads, 4 barrel intake manifold and 2 cranks one is original forged and the other is a never used polished steel or crome stroker crank with minimal surface rust. I bought them as a set at a Mopar swap meet for $540.00 in Olympia, WA. in 2012. Nice block you got there btw.
Senior citizen here not seeing any valve reliefs, street wedge block.
It's NOT 'nos'. Either is your other block.
NOS= NEW old stock.
Never used or altered from it's as-purchased state. They both have had freeze plugs installed and at least one spray job. Same bore picture in both ads..
OP responded back but still won't clarify, on this or his other thread, what's going on with the pictures??
NOS= NEW old stock.
i may have mixed up pics but they are nos blocks.freeze plugs and paint to keep from rusting makes them used???????
Not used and NOS are two different things here...do you consider an altered part still NOS?
Look don't take it personal, I'm just trying to get you to be accurate in your descriptions.
If you've mixed up the pics, that's fine, honest mistake, just fix it please...and maybe you could clear up why you're advertising your 440 service block as HP.
Just looking for clarity, that's all.
because it says hp on pad that why.and freeze plugs is altering something?i guess u have trouble keeping anti freeze in your engine then.and yes,i still conside it nos.even with your so called altering with paint and feeze plugs.i dont take it personal,we have diff opinion of nos i guess
both the 426 and 440 have hp on pad
so i guess crossram intake not nos either as it has carbs installed
Then maybe put the pics people are asking for in the proper threads? You have pic of a blank pad, what's that from? Holy crap it's like pulling teeth....good luck.
