1964 Dodge 440 Smallblock > Bigblock
cultphotos
6:09 PM
Netherlands
Hi here's my question.
I had a 360 SB in my 1964 dodge 440.
Now it's going to be a 440 BB
Do I need to get a different k-member or can I use the SB k-member?
Also I would like to know if I can use the SB k-member if I need to buy some conversion kit from engine swaps.
From what I red:
"These differ from the small block K frames in the left side motor mount area, see pic. There is no bracing in front of the mount, creating clearance for the oil pump."
Thx!
Marcel
If you have the original K-member from the '64 in it now, you don't have to change the K-frame, same for big or small block engine... However you will need to buy '63-'65 engine brackets for the big block engine....not 100% but you maybe able to use the sb insulators,(never had a sb), but I would just buy new ones, they're not that expensive, if you buy from the right supplier..Norm Brady at Cross Ram Connections....He has what you need @ the right price.. Fairly easy swap....
