SOLD 1964 Dodge 8 3/4 rear axle $200
Montclaire
1:43 AM
Scranton, PA
Feedback: +1 / =0 / -0
Clean, complete 8 3/4 rear out of a 64 dodge polara from California. Drum to drum, worked fine and pulled just a month ago. Still has most factory inspection marks. Open rear, I have to check what case casting. Asking $200, PM through board Thanks
Do you know which gears are in this rear, and if it is a posi or not? Thanks
As stated it's an open rear. I couldn't find a ratio tag, I don't know if they used those in 64, but I can tell it's pretty high. Might be 3.23 but more likely a highway gear, 2.7 or 2.9-something or in that range.
I'm near Scranton, but I might be able to meet you somewhere around Reading if I can find another reason to head that way. I can also deliver to Carlisle if paid in advance.
Do you still have this rear axle, and are you still planning on going to Carlisle next weekend? If you can still bring it I will plan on making the trip--
I should have mentioned Chrysler Carlisle in July, not the Spring or Fall matchbox and handicraft shows. My fault.
