FOUND 1964 factory hemi crossram Intake
prostockstan
10:45 AM
Lancaster Pa.
Feedback: +1 / =0 / -0
I'm looking for a correct date code 1964 hemi crossram intake manifold. If you or anyone you know has one pease contact me ASAP.
Thank you: Stan Sawyer
I know a few guys in the Detroit area with crossrams. Not sure if they are 64 or 65. One guy has a brand new one with carbs, and uses it as a centerpiece on his coffee table. I will reach out. What is the specific PN?
not sure on that yet. but I will do some more research and get back to you.
I've got an aluminum crossram, never been cut or ported, has a pretty early date, maybe pre-production. Let me know if you're interested
I am one of those guys & I am in Michigan I have a magnesium Hemi cross ram but may run it on an old 63/64/65 Dodge when I find one some day.
see if he might want to sell his conversation piece. I will go with either 64 or 65 date code.
64's came with AFB's or Holley's right? What determines which brand of carbs were put on? Friend has a 64 x ram never looked at date code on the Holley's.
One thing torquing them is a long process. Took about 3 days of re-torguing to compress the intake gaskets. Had to re-torque the bolts every 4 or 5 hours until bolts would hold there torque. Friend didn't know that almost cost him an engine. Bolt loosen an got suck/rolled down intake port. Dinged piston valve seat and valve. I re-torque mine spring and mid summer, just incase.
I found you one. With carbs he wants $5500. It looks as close to brand new as I have seen. Let me know and I will give you his number.
An ad I saw up here. Doubt it is a 64 though.
426 hemi crossram etc,
https://www.kijiji.ca/v-moteurs/vil...aign=socialbuttonsVIP&utm_content=app_android
Price: $ 2,800CAD
Thanks for the members help. I found an original 1964 crossram with plates all linkage and hardware for $2500. I drove 4 hours to corning N.Y. and met the guy 2 hours from his home in Rochester N.Y. He only asked for 25.00 in gas money. The manifold is an original 64 no porting and no modifications. I now have the block, K heads, and crossram. I didn't think I would find these pieces. Thanks to all that helped.
Stan
