1964 Plymouth Savoy Steering Column Rebuilding Services.
jobenz
10:09 AM
Branford, Connecticut
I cannot believe I cannot find a company that can rebuild my steering column and Ididit and Flaming River do not make one for my car. (WHY) Does anyone out there know what i can do to replace my manual steering shaft with a power steering shaft????? I;m not a wrench.
I know your question has been brought up before here. I'm sure someone will bring the knowledge to the table.
Its not that difficult. I went the opposite from power steering to manual with mine. Just takes quite a bit of time and the correct shaft. Also in your best interest to rebuild the coupler as they are often worn out.
The power steering shaft is about 4" shorter. You'll need one of those. Then the coupler is smaller in diameter where it attaches to the shaft. You'll need one of those.
With the steering box out you can remove the shaft without removing the whole column and replace it with the shorter shaft. The hard part is replacing the standard steering box with the 70+lb power steering box.
