1965 Dodge coronet 500 Rocker trim
bigaadams
2:34 AM
Mid Georgia
Feedback: +5 / =0 / -0
SANY0533.JPGEvening everyone...am looking to find a rear rocker molding finisher that ties in the the fender opening trim lip....pictured is the one for the passenger side....am looking for the DRIVERS side...thanks
Do you just want the mirror of the one pictured, or do you want the entire setup for both sides, including the wheel well lip trim?
Send message to Goldencommando he has 65 stuff or has friends with 65 parts also.
Thanks for the tip to Goldencommando..message has been sent....
add to my list of needs: one rear quarter molding..appears it will interchange either side..someone correct me if this is a wrong assumption. Thanks...
It wiil fit but the clip slots will be showing
I appreciate the identifier on the molding by way of the clip slots....thanks so much and by that I would need the passenger rear quarter trim section...
again...GITEX thanks for the clarification...much appreciated..
Goldencommando...your PM box is full..unable to send my e-mail..please clear some messages and let me know via a PM when you have room and will send my e-mail to you...thanks a lot.....
I also posted this on another thread you were following...thanks...
UPDATE...
I have made an error........have just been informed that I had been wrongly informed of the manner in which the rockers attach. The rocker with the stationary (tack welded connector) are actually the rear section of the rocker trim and the loose connector mounts on the front end. THUS..I need the front right rocker to fender lip trim item.
I apologize for this error....
FRONT RIGHT ROCKER CONNECTOR FOUND...THANKS ALL...!!
