WTB 1965
Mopar512Guy
8:49 AM
Salina, Ks
Feedback: +0 / =0 / -0
Needing front window stops for both RT and Lt sides.
"H" for hood to complete PLYMOUTH
Under metal for the sill plates
Radio knobs.
Still looking for an H? I also believe I have the stops you mentioned. I think you're talking about the two brackets that mount near the top of the inside of the door, one near the front and the other near the back? They're kind of an L shaped device.
Let me know either way please. Thanks
Yes that sounds fine. Feel free to direct message me with payment method and and I will get to you the shipping address information. Thanks a lot for the assistance!
Just to confirm, this is what you're expecting for the window stops. I've sent a message with payment info.
What u need ? If u still do ?
Still need:
1. The front grill emblem - Red/White/Blue
2. The interior chrome that goes over the Rt & Lt doors and passenger windows
3. Console wiring harness that has the 5 light sockets and couple plugs. It unplugs behind the kick pate under the dash just in front of the Rt door by the floor.
4. Needing 2 sets of the horn ring mounting hardware.
Rt rear corner molding (that gets painted not chrome) that is just Rt and above the light panel and is used to fill the gap where the top and side quarters come together. It bends the corner and is about 6" long.
Not sure about 5 light sockets for the console harness. I thought there were just the two near the front and one for the shift indicator on automatic cars. I THINK this is the harness, but my filing system has failed me. The part number on the tag is 2497327. This one has the two connectors for the neutral safety switch along with a connector where the console clock option would go.
I do have the right corner trim piece as shown. Still checking on the upper inside window trim.
Both of those are what I need. Do you have the harness wire that essentially connected that console harness to the 4 prong connector behind the lower Rt hand side front kick plate?
I found the inside window trim. These are in pretty nice shape for used ones. Shine up nicely. Some pretty minor pitting and one dent which I think could be worked out although it's not terribly noticeable to begin with.
You may not realize there are the two small pieces at the rear end that make the transition to the rear window upper trim. Those are shown as well and included $100.00 plus shipping. Probably best to split them into the two parts for shipping.
I also have a used set (already split) that are straight but faded and pitted pretty badly. They would certainly sand and paint up fine. Can send photos of those if you don't care about the original appearance. You could spray paint them with chrome paint. $30 for those plus shipping.
Regarding the console wiring, that's all I can find. $35.00 for that if you're interested and I'll throw in the corner trim piece. Again, plus shipping. Can combine shipping within reason, depending on shape.
I looked over the joint on the trim parts more carefully and find that they are crimped together on the outside and spot welded on the inside lip. Looking at my car the inside lip is really not visible, but in order to split these I have to break one spot weld on each side. Didn't want to proceed without your approval.
Shipping estimator comes up with $19.60 USPS priority mail (assuming they're split apart). That would be 6 trim pieces, the wiring and the corner trim piece. Let me know please. Thanks
View attachment 636367 View attachment 636368 View attachment 636369
Haven't heard back from you on this. Still interested?
