Joe Jacalone
- 5:24 PM
- Sep 7, 2021
- St. Augustine, Florida
I need the transmission crossmember for a 1966 Belvedere II. Not sure if it matters, but install a 440 with a 727.
Any V8 crossmember 66, 67, will work, also think 68-70 also.I need the transmission crossmember for a 1966 Belvedere II. Not sure if it matters, but install a 440 with a 727.
Yes but in 69 or 70 they changed to little bolts.Any V8 crossmember 66, 67, will work, also think 68-70 also.
I think I found one, but if not I will get back to you. Thanks.I have it from 66 coronet.
Do you need the one that go with 4 bolts o the one that is spot welded?
Sounds goodI think I found one, but if not I will get back to you. Thanks.
