1966 Coronet 500 - Power Window Motors - Replacement?
mag82008
12:55 PM
Ratingen, Germany
My 66 Coronet 5000 has the power window option. I am the king on all car meetings but these motors are not very reliable.
Now again, one of these motors got broken.
I have seen man motors in the internet that "look" exactly the same, but everywhere they tell you "will not fit". Last year I bought in eBay a motor which belonged to a 66 chrylser 300, the year before I got one 69 window motor, BOTH of them fitted perfect.
Now: I found some rebuild motors like
A1 Cardone 42-44
http://www.amazon.com/A1-Cardone-42-44-Window-Motor/dp/B000V9SHKK/ref=cm_cr_pr_product_top?ie=UTF8
Dorman 742-302
http://www.amazon.com/Dorman-742-302-Chrysler-Plymouth-Driver/dp/B005GN17Z8
They all look exactly the same.
Does anybody now if these will fit?
Thx
Martin
2808764 and 765 are oe numbers for motors for front doors but you need to pull all that unreliable power set up and ship it to me as i want p/w's for my r/t !!
:toothy10:Sure. Will do it immediately.
They bolt on - all I did was get slightly longer attaching bolts and you will need to thread the bolt holes. I also made a bracket similliar to the factory one (door motors). Not sure if it is nessesary because the new motors are so much lighter.
