383MovingViolation
Big block 383 with 750 Holley 4 barrel carb., 4 speed trans. Headers with new pipes and tips. It also has new Doug Header electric exhaust cut-outs, it sounds awesome with a rock’in hot cam. All new front suspension parts. A new Firm Feel sway bar. All new brakes and components. All new Coker red line tires on factory wheels, reproductions. The interior is in great condition. A full set of Autometer gauges, oil pressure, water temp, volt meter and a steering column mounted tach. It also has an Autometer fuel gauge, the factory gauge stopped working so I just added a better one. It has a factory deluxe steering wheel that is in excellent condition. The hood is steel with an added Hemi style fiber glass scoop that is functional. I also have the original hood, in excellent condition that goes with the car. I also have the original, unpainted grill. Also, a power brake booster and master cylinder that I didn’t get around to installing, you can have that too. The rear end is 2:73 open, never got around to changing it but if you don’t tell anyone they will never know the difference. Air shocks on the rear. No rust anywhere and all body panels are straight and original. The door hinges were a little sloppy so I changed them. Most of the bright work is in great condition but not show quality. It also had a new clutch, pressure plate installed. I probably forgot to list some stuff but it is a great car and fun to drive. Open the electric cut outs and heads will turn, it sounds awesome. I have owned the car for about 3 years and it’s time to move it on. I have another car so I won’t be left with nothing. If anyone is interested at $25000, let me know. The car is located in north west Ohio. THANKS
