SOLD 1967, 68, 69 383/440 HP Exhaust Manifolds
John B
12:08 AM
Fresno, CA
Feedback: +4 / =0 / -0
I have a pair of exhaust manifolds for 67-69 383/440 HP that have been hot tanked and high temp cleared. These are in good condition, the RH was cracked and repaired by my engine builder that has done hundreds these type of repairs with spray welding. I spent almost $200 to get them ready to sell. Look at the pics, the part numbers and date codes are there and the condition is easy to see.
If you looking for Concours correct they probably won't work unless you can be a little creative on the repair to look factory but I couldn't see trashing the RH for a common crack. The RH has a good working heat riser, it needs the spring on the rear to be perfect. You could resurfaces the RH as it is off 0.015 in the center from welding or just get the #6002 RemFlex gasket from Summit for $35 and it'll seal perfectly. I am including the original mounting hardware which you might have to replace a couple of nuts but has the correct, original deep nuts.
I'm looking to get $500 plus the ride, pm me for shipping details with your zip code. They are in Year one boxes because I went with the repops. I tried to be as honest as possible in the listing, let me know if you have questions. Thanks, John
IMG_4650.JPG IMG_4638.JPG IMG_4640.JPG IMG_4651.JPG IMG_4648.JPG IMG_4647.JPG IMG_4642.JPG IMG_4649.JPG IMG_4653.JPG
