1967 coronet rt clutch size
67RT
11:55 PM
Akron,Ohio
While removing the clutch I noticed that it was a 10.5 inch with a 130 tooth flywheel the engine is a 440. That clutch and flywheel combo from what I could find is for a small block.why would a big block have that combo.
That is not necessarily a small block combo. Lots of people use 130 tooth flywheels and 10.5" clutches because of the reduced weight and broader availability of clutch discs. I would consider it an upgrade.
