1968 Charger R/T steering column collar install
Frank68
5:29 AM
Lakewood, CA
I'm having issues with the steering column collar(s) on my floor shift 68 Charger. I changed the steering wheel out for an original wood grain one, and when I was "done", the collar that houses the turn signal mechanism was LOOSE. So loose that when I would go to use the turn signal while driving, the entire collar would rotate about 2 inches in either direction. I moved around the other collar and I think I made it worse! I can't figure out how these collars fit together, and what prevents them from rotating freely. Please help?
Graveyard Cars episode S9E8. 4/25/2018. 68 Charger steering column info. Check it out.
