WTB 1968 reverse light switch for column shift
Richard Cranium
12:30 AM
New Hampster
Feedback: 28 / 0 / 0
Looking for a 1968 column shift reverse switch, attaching screws and the plug (with pig tails) from the dash wiring harness. Thanks!
Do you even have the rod that activates the switch??? This plastic part nearly always broke off and disabled the switch. It gets mounted on the rod that goes through the firewall. Mine was gone when I bought the car. I found an NOS one a few years ago and it was so old, it snapped when I tried to install it. That was a wasted $15. Does anyone know a good way to add something to engage this switch?
no I don't , you should be able to fab something out of an alum rod or something of the sort. this is off a spare column I'm junking out.
X2 on the plastic post it is unobtainium. I went with the 3 prong switch on the trans with a harness. The switch is still on the column though. The FSM says to break the post off to service/rebuild column. 40 year old plastic aint what it used to be.
If silversedan don't get you fixed up i have those pieces
