1969 Dodge Charger Project Shell!
69 Charger 500 Fanatic
12:19 PM
Louisville, KY
Feedback: 1 / 0 / 0
1969 Dodge Charger Project Shell ~ $9500.00 ~!
1969 Dodge Charger Project.
$9500.00
An absolute perfect opportunity right now, to build a 69 Dodge Charger pretty much anyway you want, body color, interior color, engine combo, etc.
I have no additional parts that go with this car other than the VIN tag and a title. The rear end and leaf springs that are currently under the car are not included.
This Charger has approximately $13,000.00 of AMD sheet metal & components on it alone "excluding installation labor" and other expenses. For the "Buy It Now" price, there is no way you can build one comparable!
It will need finish welding, grinding, seam sealer, etc, etc, etc! The front half of the rear frame rails were modified and reinforced and do not look original because the previous owner was building another General Lee clone but this can changed back to original if you want. It also has frame connectors.
Will be happy to assist with delivery or help with delivery arrangements. I have connections with a couple of transport companies that can help for reasonable rates.
Below is a list of the new AMD sheet metal parts on & in this car.
Hood
Left Fender
Right Fender
Radiator Core Support Assembly
Left Door Shell
Right Door Shell
Left Rocker
Right Rocker
Left Front Floor Pan
Right Front Floor Pan
Left Rear Foot Floor Pan
Right Rear Foot Floor Pan
Left Side Trunk Pan
Right Side Trunk Pan
Left Trunk Pan Extension
Right Trunk Pan Extension
L & R Trunk Floor Valance Reinforcement
Left Rear Frame Rail
Right Rear Frame Rail
Left Rear Leaf Spring Mount
Right Rear Leaf Spring Mount
Rear Upper Shock Crossmember
Left Inner Wheel House
Right Inner Wheel House
Left Outer Wheel House
Right Outer Wheel House
Roof Skin
Roof Rear Upper Bow Structure
Deck Filler Panel
Deck Filler Panel Lower Plenum
Left Full 1/4 Panel
Right Full 1/4 Panel
Left Trunk Gutter
Right Trunk Gutter
Trunk Lid
Tail Light Panel
L & R Tail Light Panel Reinforcement Brackets
Rear Valance Panel
Left Corner Valance Corner
Right Corner Valance Corner
Thanks for the interest!!!
Should have made a list of what wasn't replaced. You could have spared yourself carpal tunnel syndrome.:toothy12:
ugh........OK......I marked this car as "sale pending" and it is as I do have the buyers $250.00 deposit but when speaking to him last, his wording indicates to me that there may be a problem and that his full purchase "may" not happen so....... I am keeping this alive and if someone else is interested, please let me know and we'll go from there.
Thank you!!! :D
Looks like this will make someone a good buy. Looks like all the hard work & labor is already done. Good luck on sale.
