BLANCK88
- 8:07 PM
- May 28, 2016
Anyone know where I can get a new pair of upper and lower steering column bushings for my 69 gtx??
thanks
thanks
Are you referring to the lower white nylon bearing that is visible on the lower steering column? This bearing is reproduced and you will need to know if yours is either a two or three bolt pattern. Most of the larger vendors and restoration suppliers will carry them. The upper bearing was available from Chrysler, but I have not ordered any in the past two years, so I cannot say how difficult they will be to locate. If your unable to find the bearings through your favorite vendor, drop me a message as I do stock them.
