1969 Roadrunner Dash Paint Help & Sources
superbird77
1:26 AM
West Michigan
I am trying to restore my 1969 RR dash frame, switch control panel and steering column. What are the correct paints for the frame, switch panel and steering column? The switch panel looks a bit textured. Where can i source these paints? All are black FYI. Thanks!
All I did for mine was I went to the local hardware store and got a couple spray cans of rustoleum semi-gloss black for my dash and switch panel. Haven't done my steering column yet, but will probably use the same paint. You could do an advanced search for "painting the dash" and see what that brings up. Maybe someone like Eastwood would have something if you are doing a correct resto.
