1969 Roadrunner suspension questions...
akers63
1:53 PM
north carolina
I have a 69 roadrunner and I want to lower it a few inches, does anyone know of a good company that makes lowering suspension? What are some of my best options for lowering the roadrunner?
You can loosen the torsion bars some and see how you like that, or get 2 inch drop spindles "$$$", all depends on the route you want to go!
Thanks, I'll try it and see if its what I want, like i said i want to go a few inches like 3-4in in the front and 2-3 in the rear.
magnumforce makes 2" drop spindles for the front IIRC
if you wind up dropping the t-bars down, make sure you get an alignment if you keep it that way...or else it will eat the inside tread of your tires DAMHIK
if your gonna drop it that much you will need the drop spindles.lowering the tortion bar that much will never allow for camber to come back into spec.
not sure if this will affect it but make sure your rim will still fit over UCA & brakes if using the 2" drop spindle, all depends on your size of rim i guess,
Hotchkis and I believe PST make lowering blocks for the rear. Just go between the perch on the bottom of the rear axle and the leaf springs. Pretty cheap.
