69 500
1970 hemi engine casting date 11/11/68 was in 70 hemi cuda,all machine work completed and all new parts in there perspective parts and or reconditioned motor is a part for your inspection, block is .020 over bore, heads are virgin heads with 5 angle valve job, heads are gasket ported , and engine assembly balanced, the carbs a pair of 1970 4sd carbs and date coded for early build date. the car that it belongs to is still around and I will forwarded this info if so desired. for detailed description pm for phone number $30,000.00 located 26062
