1970 GTX 3 speed wiper switch
70GETEX
5:37 PM
Grand Island NE
Is anyone making new 3 speed wiper switches?
My motor runs when I jumper it and I have a new wiring harness so I think my switch is bad.
Thanks for the info Jim, much appreciated! I got my dash wiring harness from Year one, much better than the one that was in the car. The guy that started the restoration tried his best to make the original one work but he had quite a mess!
70GETEX if you don't mind I have a somewhat related question.
Are 68 - 69 - 70 three (3) speed switches interchangeable among years and Rallye and non-rallye dashes?
I have a 69 3 speed switch from a Rally cluster and need one for my 68 NON rallye coronet R/T. I have not taken the one out of the R/T as that's a later project.
What are the differences in the switches between Rallye and NON Rallye dashes if any?
Width of the rocker on the switches. I believe you can go non rallye to rallye but the switch is not as wide on the non rallye so there would be a space on the sides of the rocker. I'll check with Jim at JS Restorations to be sure, but I believe that is one of the main differences. I could be wrong...I'm far from perfect on switches and how they interchange. Switches just aren't my specialty, thus I rely on Jim for any switch questions I have :p
Is your Wiper motor correct for a 70? I have a different year wiper motor, and found that the wires were reversed at the terminal block to accommodate the motor swap. G
