1970 rear window issue.
Mark1972
Winnipeg
The other day my 1970 Satellite went to the glass shop to have the rear window installed. It's the original window out of the car. I was told there isnt enough room for the window side to side. Top to bottom was fine, but side to side no. They said a 1/4" of room is required all around the window for proper spacing, and there is only about 1/16" on each side which wont leave enough room for the polyurethane sealer. I only have a few more days before the car goes into storage. I'm desperate to get the rear window in before then. I also cant start cutting the back window metal apart. Does anyone have any experience with rear windows or has run into this before? Any help would be much appreciated.
Find a different shop or do the glass yourself. The rear glass is sealed to the body using butyl rope not urethane ! It literally just lays on top of the butyl, and somewhat held down by the stainless trim...Front uses liquid butyl, not urethane ... it makes a difference on these old cars.
1/16 is plenty of room. If it clears the clips for the moldings, it will work. 1/8 butyl tape using the good stuff. The front uses a gasket with butyl tape on the bottom and about 3 inches up the sides from the bottom.
Sounds good. I will look at installing the glass myself. I've taught myself how to do everything else, lol. I'll see if I can find a tutorial on DIY rear window for this age if car. Thanks again.
I have to reseal my back glass on my car
Where do you get the tape
I just did the front with the special caulking that people suggested and worked great
No leaks from that
Post a pic or p/n
3m butyl rope, I think 3/16 is what I used ... I think ! It comes with spacer blocks for the bottom of the glass to rest on. Make sure everything is clean and dry, it will stick as soon as it touches. I get my stuff from my local auto glass guy. There's always Amazon though ....
