1972 Charger Ignition Key Swap
Jarran
12:30 AM
Hayward, CA
I just got a new set of locks for my charger and the kit came with a replacement for the ignition as well. I don't see how to swap it out. If anyone has some information or has done this before that would be great, pictures would definitely help!
you may want to get a sevice manual to change that.if i remember correct that lock cylinder is in the steering column.that means you will need to pull the steering wheel and several things under that to get at a spot to push it a release pin on the cylinder.after that it changes out pretty easy.
