SOLD 1972 Mopar 440 Steel Crank Engine Long Block
challengersteve
3:33 AM
alma arkansas
Feedback: 18 / 0 / 1
You are buying a 1972 Mopar 440 Steel Crank Long Block Assembly.
This engine had NEVER BEEN APART and is Standard Bore. This turns over fine and there is no damage or pitting in the bores.
This will need rebuilt as it has been sitting for years but should bore .030 as this is standard bore.
This includes the complete block assembly with crank, balancer, rods, pistons and heads and rocker gear. The motor mounts and accessories are not includes but are available.
I will be shipping this Truck Freight but local pickup is of course welcome.
This is 850.00 plus shipping or local pickup is welcome in Alma, Arkansas 72921.
I accept paypal and credit cards over the phone.
Thank you very much, Steve Schweitzer
STEVE I need a cast crank accessories pulleys and brackets for 73 440 with ps alt and water pump going into a 66 charger ,mine was pulled from a 73 imp that had ac .... does the wp housing also need to be changed to a non ac?
Hello, the water pump housing should be the same for a/c and non a/c. I do not have the non a/c pulleys and brackets as is is fairly rare to find these cast crank 440 engines without air. I probably have the power steering pump with the correct brackets but nothing else.
Thanks, Steve
