1972 Satellite brake options
theGreenOrange
5:28 AM
New Orleans, Louisiana
Does anybody know if manual disc brakes were an option in 72? My satellite has terrible brakes, no response until the end of travel and then it finally brakes if you stand on it. I replaced wheel cylinders, rotors, soft hoses (one side still old hose, would not come off), master cylinder, drum rebuild kit, etc. They still suck. I bled them several times, and a mechanic did the master cylinder and bled them for me while in for leaf springs.
I am thinking maybe the car was originally power brakes and the booster was removed. Would this cause the behavior I'm seeing? The rod is a different for power and manual, right? Was manual brakes with front disc even an option on the 72 Satellite (Sebring)?
Thanks if you can help. I guess I want to get a booster but don't know what else is required. Any ideas what to check or replace?
I'm not sure if nobody knows, or if this question is just too stupid... Any ideas on what may be the issue is appreciated, thanks.
I have a basket case 71 SSP and it has manual disc brakes. Not sure if those were factory or not. No build sheet or fender tag when I bought it.
Thanks, that post was actually a big help! I didn't think of looking at the fender tag. I decoded the fender tag and it turns out it did have power brakes. Power brakes and disc brakes were listed as separate options, although I'm still not positive they were available independently. Anyways, here's what I got from the fender tag.
RH23:
Plymouth Belvedere,Satellite
High
2 Door Hardtop
G2G: 318 150HP(net) or 155HP(net) 1-2BBL 8 CYL
1972
St. Louis, MO, USA
XXXXXX: Sequence number
E44: 318 cid 2 barrel V8 230hp
D34: Light Duty Automatic Transmission
GF7: Sherwood Green Poly Exterior Color
C2F6: Trim - Charger, Vinyl Bench Seat, Green
GF7: Sherwood Green Poly Int. Door Frames
522: Build Date: May 22
XXXXXX: Order number
V4X: Unknown Top Color
U: USA Specifications
B41: Front Disc Brakes w/Standard 10in RR Drum
B51: Power Brakes
G11: Tinted Glass (all)
G37: OS Dual Racing Mirrors
H51: Air Conditioning with Heater
J25: 3 Speed Wipers
J52: Inside Hood Release
L31: Hood/Fender Mounted Turn Signals
M21: Roof drip rail moldings
M33: Body Side Moldings
R11: Radio Solid State AM (2 Watts)
V5X: Body Side Stripes, Black
26: 26in Radiator
END: End of Sales Codes
I have a hunch the PO just removed the booster and used the same rod (I can't remember the real name of the part, but it's the plunger rod through the firewall into the MC from the brake pedal assembly).
Thanks!:icon_kidra:
Maybe it was the pedal linkage that is different? I don't really need to convert to power brakes at this point, I have lots more stuff to do before that. So if I can just get the manual brakes working right that would be great.
Auto parts stores list the same master cylinder as being used for power and manual brakes.
Does anyone know what other parts should be changed to convert a power brake setup to manual?
