1973 Challenger Rallye from Lakeport, CA
GUMM B
6:35 PM
Lakeport, CA 95453
I'm not sure if I ever did an introduction post so here's my embarrassing story:
Five years ago, I bought a 1973 Dodge Challenger Rallye for $30,000 that was advertised as having a numbers-matching 340 4-Barrel with only 43,000 original miles from a guy named Lunardi in Livermore, CA who told me he was the 2nd owner. I was so happy to get in it and head towards home before it blew up on the freeway. I towed it that night to a shop called General Motors nearby in Novato that had a good reputation for restoring classics. The mechanic told me I got swindled. The motor was a 1990 360 LA motor with a Holly 4-barrel and he said the car looked to have at least 200,000 miles on it.
He sent the motor to a machine shop in Santa Rosa, got it back from machining with close to stock numbers, assembled the motor with a peppy camshaft and some other respectable parts from Summit Racing, and charged me about $12,000-$15,000.
Within a couple months and 400 miles, the oil was leaking from the front and rear main seals and probably other places. I told a local race car mechanic about it and he did a compression test and probably some other test. He said there was piston blow-by that was probably pressurizing the crank case enough to force oil out of all the gaskets. The first mechanic blamed the machine shop and the machine shop blamed the first mechanic so neither of them took responsibility and I got screwed.
The original A-904 automatic transmission also blew up (literally blew chunks of metal) so I had a local Mopar transmission specialist replace it with the A-518 4-speed automatic that he was using in his 1970 Barracuda Gran Coup. Now when I'm cruising in the fast lane, I flick this overdrive toggle switch and the car goes right to sleep.
:bananadance:
My local racecar mechanic sent the motor to get re-machined. He's decking and blueprinting the motor and stroking it to 408. I decided I wanted to go with a Holly Sniper EFI and race up the entire chassis.
Over the last three years, I've sold all of the original suspension components, the power-steering and linkage components, K-Frame, 8-3/4" rear end, power front disc / rear drum brake system, and wheels on FEBO, FABO, FBBO, FCBO, Mopar-related Facebook groups, and eBay.
My local race car mechanic talked me into having him install all of his favorite custom race parts:
  • MSD Ignition
  • Blueprinted and decked 360 LA stroked to 408 with a lopey cam
  • Holly Sniper EFI System (was my choice for an easy-start daily driver that I can map between pump and E85)
  • 2.5" full exhaust system from exhaust port to tip
  • Full manual valve body shift kit in the A518 4-speed automatic paired to the existing B&M slapstick shifter
  • Ford 9" full locking rearend with 3.50 gears
  • Manual rack & pinion steering
  • Coil over suspension
  • 3-link rear
  • Manual 4-wheel disc brake system
  • 15"x8" front and 15"x10" rear slot mag rims
I don't feel as guilty cutting, chopping, and changing the bones of a 1973 as I would a 1970-1971 E-Body. And so far, I've placed each and every part, nut and bolt that I've removed from my Challenger onto over 30 classic Mopars from California to Sweden.
I'm sure I'm leaving things out but the most important upgrade is that I replaced the "LUNARDI" license plate with one that says "GUMM B".
I told my local racecar mechanic that I'm not in a hurry to get the car back until I've sold all of the old parts to clear room in my garage for the car. So yes, it's been over three years since I've sat in what's supposed to be my daily driver.
I'm coming here to sell the last few remaining engine parts that are still good and that I haven't lost in my garage from the first mechanic's rebuild 500 miles ago. Once I clear my garage, I'll let my mechanic know that I'm ready.
Dang! And I was feeling bad about having discovered that my 66 has 67 fenders. Thanks for putting things in perspective.
Welcome from down the hill (in Napa).
Welcome from Southern CA, Orange County.
Quite a story there, and it's nice to hear a good outcome, if you can call it that !!
Hope you get the car back soon, and then you'll have a lot of good times so you can forget about the bad times.
Thank you! I hope so too!
Welcome to FBBO from NorCal Sierras, Tuolumne Co.
quite the story, new plates should read 'GOTSRCUD'
some bad decisions & people working on stuff
caveat emptor
other than that, a nice irde
sorry, to say
not knowing what you're buying is the 1st sin,
"fill your library, before you fill your garage"
You not knowing how to fix it, or work on it, paying someone else to do it
that is the 2nd sin,
should have had someone that knows what they're looking at
check it out 1st, could have saved a crapload of issues, time & $$$
the build cost of the new motor build, for a street driven SBM
to me that seems a bit steep @ $12,000-$15,000 is 3rd sin
seems like, they are all playing you
'sorry the truth stings sometimes'
we are brutally honest here
good luck with the E-Body
maybe also check out, E-body forum
