2 questions.
MoparEd
10:54 PM
German triangle, Mi
1st one does the motor mounts from a 318 poly work on a Big Block motor(413 block).
2nd, I am putting a newer transmission 727 big block, in 65 Belvedere. i did find out that I can use the trans mount, but I have to change the rubber mounting bracket part. the question is who sells a conversion mount or is there something different I can use. I heard something about a small block mount.
Going to the Nats so will be looking.
You will need b/b motor mounts and a trans conversion mount. Schumacher Creative Services has everything you need. Just go to there site. If you use a later model 727 you will also need a differant steering column or a floor shifter. 65's have a cable operated steering column and trans. a 66 steering column works the best. Hope this helps, John
Call-
Shumacher Creative Services
they can answer all your questions and supply the correct mounts.......
