SOLD 26" small block radiator
Stroked408
6:05 PM
Feedback: +0 / =0 / -0
This 26" radiator came out of a bone stock 1970 Dodge Challenger with a 318 and factory A/C. It has been hot tanked but not fixed. It will need to be re-cored. Stamping on top is 2980 799.
Your cost to have this re-cored should be cheaper than mine here in the Bay Area.
I checked Glen Ray radiators and they don't list this stamping number under 26" small block radiators. So if you are doing a correct numbers matching restoration, this may be what you're looking for.
$120 Located in Hayward, CA 94544
I think your part number might be 2960 799 - that's showing up in some of my info. Seems this one might be both 70 and 71, but not sure. Should be a date code stamped into one of the mount flanges (I forget which one) if you can find it. You be the judge
Mark
Thank you for the information Mark. Now that I look at it again, that is most likely a 6 on the stamping. The 318 was an automatic.
