3.23 gears for Dana 60
andyf
3:31 PM
Oregon
When Doctor Diff first came out with the 3.23 gears for the Dana 60 I signed up to be the test case. That was a few years back and so far all good. He had Strange put together a new S60 for my '65 Coronet and he hung his rear disc brake kit on it. I went with the 3.23 gears since I'm using a Doug Nash five speed that has the extra low first gear. I was running 3.54 gears before and they were just a tad too low in first gear.
Is strange going to start offering the 3.23 gear set? I ask as I’m looking to order a S60 and I’m local to Strange
IIRC they make a 3.31:1 gear for a Dana 60...
or they used to anyway, it was used in some 4x4's IIRC
where to get them I don't know
Summit Racing has the front/reverse rotation gear in 3.31:1,
'Motive Gear' brand
but no listing for the rears
I have bought 2 S60's now, both through Cass, 1 with 3.23's. From what I remember, they were cheaper going through Cass than directly from Strange. It would be worth checking out to buy from Cass and pick up at Strange.
Who is Cass?
'Motive Gear' brand
I think the 3.31s are for a dana 61. Looks exactly like a 60, but a different carrier that can use higher gears. I think there was a 3.07 too (3.08?).
'Motive Gear' brand
Dana never made anything taller (lower numerically) for a Dana 60 than 3.54
Dana 61's can be had in 3.07, 3.31 (which I use), 3.54, 3.73, and 4.11 They are different because a Dana 61 has the pinion moved over 3/8" to the side compared to a Dana 60 to allow for a larger diameter pinion gear required as you get taller (numerically lower) in gear sets.
Dana 61's can be had in 3.07 (I had a F-250 with 3.07 gears and loved it)
I have a Dana 61 I put in a 69 AMC Rambler and run a set of 3.31 gears in it.
Tom
Tom
What vehicle do the 61s come in?
