3/8 for power steering return hose.
Don, just from memory 11/32" hose for the return side. If I'm wrong somebody will correct me I'm sure. For some reason I'm thinking 3/8" was used to. It might depend on the power steering unit being used.
Your right about the 11/32 hose KELLY, I cant see it being a problem using 3/8 its just a return hose no pressure.
I suggest you use transmission cooler hose (or similar) since oils (like p/s fluid) can degrade some hose material....not sure about fuel line 3/8"
