383 block / Steel Crank / 915 Heads
NewRevNorton
5:39 PM
Falkville, AL
383 Big Block - New distributor bushing and cam bearings already installed. Comes with rods that have been blasted and the steel crank that has never been cut and only needs polishing. I have rod bearings but they Sat in the shop for a while and have some minimal surface rust. Just needs to be bored and needs the pistons. Block is currently cut .40 over. Also have a set of the closed chamber 915 casting heads that need to be worked. All parts were checked at the machine shop and have no cracks. I'll deliver reasonable distances or ship if needed. Call me if interested. *** *** ****
383 block
how much for block and crank?
PM Sent.
I'll consider trades on the remaining items as well. I'm in need of a carburetor that is around 750 cfm, black coronet door panels, 383 headers, and aftermarket wheels. I want the wheels to be 17s or 18s and 5x4.5 pattern.
