383 Valley Pan w/ Heat Riser Block Off
VANDAN
10:45 PM
Western NY
I've seen this Pan Option discussed here before, but can't locate the thread. Does anyone have a Mfg & Part # for a "B" Engine, 383, Valley Pan, the has the heat riser ports blocked off ? Getting ready to do an Intake swap, and would like the ports closed. Thanks for any info...
One time I cut some aluminum flashing folded it up and pushed it into both ends of the intake in the crossover passages.
It was still in there no issues when I pulled it apart years later.
A buddy of mine uses tin foil....but a piece of aluminum can also be cut to fit and laid in with the gasket which I've done before.
Yep, Fel-Pro 1214. Just ordered a new one after doing some work in my intake manifold. 30.42 on Amazon. Delivered in a week.
