426 hemi conversion mounts
Beekeeper
It’s a disease without a cure!
7:08 AM
Rogersville,TN.
Has anyone used or have any opinions on the Hemi conversion mounts by tin man fabrications like engine placement and quality. They are quite expensive but Schumacher is out of buisness it seems and not sure about Arruzza.
Here's my 2 cents on mounts. I've got the Schu's (never used Arruzza) but a reconfig of the dipstick is required
I have looked at all of them and when I get to it I am going to make my own. I wanted Schumacher's but they are gone, I also don't know about Arruzza's but I think the Tim Man mounts are way too expensive.
I agree they are expensive! Where are the specs or measurements to locate the hemi in the factory location? I can fab my own as well with that info
Went to look for Hemi motor mount to k member pattern, no luck. I took a pattern when I had engine out of my Satellite. Got one more place to look.
Maybe a member has a K member and can make pattern for you.
Now that would be most greatly appreciated would make it easier if I could just make a hemi k member.
I thought I remembered where patterns were with 90% certainly. After half hour looking for a White Owl Cigar box found it!! Was 100% wrong, only some patterns for fuel line bends and and pattern for X ram brackets.
thanks for taking the time to look for them I really appreciate it:thumbsup:
I can make yours into a Hemi K. Mine are the most accurate, correct ones made, all parts are Welded on A welding fixture I also make the steel motor mounts. PM if you’re interested
I just read that USCT Motorsports is going to be making the Schumacher hemi conversion mounts. I just checked their website and they don't list them but might try calling them.
Fwiw I believe my car came with the Schumacher mounts. (engine was in it when I bought it).
They were way too high to run a chrome dome air cleaner, I had to modify them to lower the engine in the car.
