bishop
Does anyone know for sure if you have to "invert" the passanger side shock tower to get a 426 HEMI? I know the factory did this but is it a must
Thanks Brian
Thanks Brian
As far as I now the 64-65 B Bodies have the same engine bay. We're running a 65 Hemi Coronet. We do not have inverted shock towers. The inverted shock towers were so you can get the head and valve cover off with out doping the shock stud.
We can get the valve covers off no problem other than we have to drop the shock down thrugh the hole. We've gotten the head of the same way.
Now the one thing I did do is cut a round hole on the stock tower right where the curve is closest to the valve cover. It gives you a little more clearence.
So to answer your question... You should NOT have to replace the shock tower with an inverted one.
