426 Wedge Head
jfro
2:33 PM
louisville ky.
I'm in need of a 426 Max Wedge Head for my 64 Savoy. Part #2406518
My head is beyond repair.
Thanks In Advance
John
jfro@bellsouth.net
Check the number again. It's highly likely you have 516's as those are the common old closed chamber small EXH valve heads.
Yeah jfro. The casting #2406518 (part# 2406736) for that year were for Max Wedge heads.. Non-Max heads are casting #2406516 - part# 2406732
http://www.tonysparts.com/BrowseResults.asp
Price Part Number Description
$1695 426 WEDGE HP 1-16-64, "V" 3-2 ASSY DATE, STANDARD BORE, MAGNYFLUXED GOOD
$1595 ORIGINAL CROSSRAM INTAKE
$395ea 3705 3705 63-4 CARBURETORS
$325 2098725 - 2098582 62-3 STAGE 1 + 2 DISTRIBUTOR
$395 2444335 64 STAGE 3 DISTRIBUTOR
$1395pr 2402286 STAGE 1 HEADS, COMPLETE, NOT CRACKED
$445 2402286 STAGE 1 HEAD, BARE, NOT CRACKED, SURFACED ON INTAKE SURFACE
$395 2402286 STAGE 1 HEAD, BARE, NOT CRACKED, BEEN PLANED ON BLOCK + HEAD SURFACE
$150 2402286 STAGE 1 HEAD, BARE, HAS BAD CRACK THRU COMBUSTION CHAMBER + HEAD BOLT
$595 2406518 STAGE 3 HEAD, BARE, HAD REPAIR ON EXH PORT + UNDER VALVE SPRING, PRESSURE TESTED GOOD
$45set PN#3771 GRANT 413 STD PISTON RINGS
