FOR SALE 440 Engine...Runner
Dutchrebuild
3:21 PM
Feedback: +18 / =0 / -0
This started as a steel crank 1973 .040 over bored 440 that was a remanufactured engine...ran great and had super low miles on reman...so I took it apart... bearings and rings were fine...crank .010/.010 if I remember correctly...I put a new rear main seal in it...new 402 oil pan...melling pump... windege tray...heads are 516 casting close chambers with new 208/174 stainless Ferrara valves... new guides and seats...cut .020 steel shim head gaskets...484 Mopar purple shaft cam...TM7 intake... electronic Mopar distributor...engine runs excellent and you can rear it run... asking $3,800 located in 14111 PM if interested
Also note that carb, pulleys, starter, headers, and brackets are not included as I use them on all engines going on my run stand
Location might help.
FYI:
HELPLINE 4 U !!
Zip Code He Lists Is "14111" USPS Decodes That Zip To: NORTH COLLINS NEW YORK........................
PS:
Call Cumo's Taxi Service For a "RIDE".....................................
