440 motor internally or externally balanced
Ralph Cali
6:33 AM
NJ
All, how would I determine if I have an internally or externally balanced motor. It is a 12/1972 date coded 440 block for 1973 car. It was rebuilt by an engine builder with a 4340 forged steel stroker crank making it a 522 cubic inch.
I am going to replace the flywheel and not sure what to buy.
Any advise welcome
Ralph
Generally speaking if it has a forged crank in it one would expect it to be internally balanced. I would further suspect internal balancing if it was stroked. But that engine from the factory with that cast date likely came with a cast crank and was externally balanced. How thick is the harmonic balancer?
Any advise welcome
Ralph
I dont know of anyone producing 4340 steel crankshafts in an externaly balanced version.
Brain, I checked the balancer and it was about 1 to 1 1/4" thick
Externally balanced engines will have a significant weight placed off center on the harmonic absorber and flywheel. If your flywheel just has the normal drill pecks in a couple of places then it might be safe to say it's internally balanced. I am also unaware of any 4340 cranks requiring external balancing.
thanks to all
I plan on buying a new 143 tooth flywheel for the car and then I would be purchasing one that is for internal balance
Is that a zero balance ?
Ralph
