62-65 Motor Mounts - poly and wedge
lacrebob
7:43 AM
La Crescenta, CA
Feedback: 1 / 0 / 0
I'm looking for 62-65 motor mount brackets for 318 poly, 361, or 383 - they should all be the same.
The slant 6 and hemi mounts will not work for me.
I do not need the insulators that connect the two brackets on each side of the engine.
The 361-383 brkts. are similar but they are taller(big block)
you have to get small block brackets they are not the same as big block. bob
I have a pair of small block mounts from a 63 plymouth fury 318 car pm me if you are interested.
jld440
Do you just need the bracket that bolts
To the block or the rubber part ? I have
Both of them 30.00 plus shipping gets both
Parts of the mount
I have a 1962. I need the brackets that bolt to the K frame on one side and the motor mount insulator on the other side.
