63 dodge polara right brake light issue
funnycar
9:12 AM
ankeny iowa
so my issue is.
i have no passinger side brake light.left side works just fine.with key off as soon as i hit the brakes no brake light on passneger side but drivers works but my dash right side turn indicater comes on .
with key on tail lights both sides work turn signal works on passenger side.
ive installed new colum signal switch brake switch to pedal bulbs.im stumpped.
thank you
Sounds like a bad ground to me. Break out your multimeter.
thanks for input.
so if my turn siganl works but not my brake light could still be a ground.
im not good at trouble shooting as you tell .
how would you test with the mulitimeter
Turning signal switch is very well the culprit. Dunno the quality of the piece you got. On rest position, the wire coming from pedal brake switch is linked to the rear tail light internally. Passenger side conection could be damaged and loosing the conection while turning switch in rest.
You can try a jumper wire at turning switch plug. On later models dark brown and dark green are the rear high intensity lights ( brakes, turnings, hazzards ). One is one side, the other is the other side... can't recall which color is which side. If you jump out the wire coming from brake pedal switch ( usualy white ) with each one of those wires, they will come on as soon you give brakes. If they do, will confirm switch is not working propperly.
Can't tell the colors mentioned are the same for 63, but with just checking the color arriving to the right side tail light you can confirm that and jump out that wire into the turning switch plug.
Anyway, if you say turnings are working propperly, the failure is still pretty much at turning switch which is missing the internal contacts for brake lights function
