64 Dodge 330 Instrument cluster plastic removal & restoration ?'s
fuseable
1:00 AM
Kansas City
What is the best way to remove the plastic trim from the instrument cluster? Anybody have a plastic dash restorer to recommend?
Drop the steering column down!Just unscrew the bezel from dash! Remove the htr.switch from gauge housing! Do Not pull hoses off the switch!!! The plastic is brittle and will break the nipples off.Unhook the battery, wires from amp gauge, speedo cable,remove headlight switch, Remove the screws holding bezel to the cluster! Contact me for the rechromed plastics!
