FOR SALE 64 Plymouth Sport Fury S/S Tribute
mopar blood
7:22 AM
n.y.
Feedback: 2 / 0 / 0
1964 Plymouth Sport Fury
472 Hemi
Charlie Pan with external oiling system
4.15 stroke crank
Holley Carbs 4236-4235 Race Hemi
Custom fit Hemi Taylor 8mm
Stage V Rockers
MSD Distributor Pro Billet 8546
Headers are ceramic-coated
Comp Cam -634-585
Pistons 11.5:1
Mopar crossram manifold (ported)
Original 64-65 Crossram Air Cleaner
Custom aluminum alternator bracket
Custom aluminum radiator with electric fan to turn on at 170 degrees
With special overflow aluminum container
Front disc SSBC brakes
New rear drum assembly
Passon performance aluminum four speed
New Brewers four speed Hurst shifter
Scattershield
Mini starter
New Dana 60 Strange S-Trac posi 3.73 gears
New Super Stock springs with poly bushings 002-003 4 speed springs
Custom SS gas tank
New Aero Motive fuel system: pump and circuit board
Aero fuel regulator
Driveshaft: 3" custom DynaTech
3" exhaust
Flowmaster mufflers
Doug's electric cutouts
H pipe
Heater box removed
Old school Sun tach oil pressure, water temp, and fuel pressure gauges
Heavy duty front sway bar
Heavy duty tie rods
64 Hemi K frame with skid plate
Welded frame connectors
No Rust Anywhere!
SS Crossram adapter plate
Headers 625214
SS velocity stacks
New Super stock battery and battery plate
Original 64 spare with 64 air
Hemi SS grill: New anodized by Hemi Eddy
Steel hood hemi scoop without hinge springs
M/T tires
Torque Thrust rims
Rear M&H muscle car tires
Factory bucket seats
New windshield
MSD coil blaster
Flaming river steering box
Dual reservoir master cylinder
Poly strut rod bushings
Clutch: new McLeod dual disc and throw-out bearing
New Hurst Line Loc
Car floor has heat/sound insulation
Custom wheel-lip mouldings
has original factory spare tire w/air
horns work!
wipers work,
currently on road.
58K
Phone number removed from sale ad for your internet security. Not allowed.
