FOR SALE 65 Belvedere parts grab bag
65hemi
8:40 AM
Winnipeg, Manitoba
Feedback: +0 / =0 / -0
Checking to see if there is any interest in these.
I am cleaning out the garage and these are the parts that were accumulated but not used for my 65 Belvedere.
I want to sell everything as a single lot; take them all.
Pick up only as there are lots of boxes.
$1500 for everything.
front windshield - original with 50 years of patina, no cracks
carpet for 65 Belvedere I - red - new in box
interior front door panel and rear panel skins - two tone red, probably from Belvedere II
interior windshield trim - used
727 trans oil pan - slightly used for mock-up
master cylinder, 1 1/16" cast iron - new
2 horn rings; half circle - used
2 front exterior door handles - used
2 1965 Belvedere I tail light lenses - used
2 1965 Belvedere I front parking light lenses - used
chrome thermostat housing
7 blade clutch fan - about 19 " diameter - used
7 blade clutch fan - about 18" diameter - PN 2863216 - used
6 blade fan
wiper pivot seal kit - 62-65 b body
65 interior screw kit - left overs
65 exterior screw kit - left overs
65 underhood screw kit - left overs
62-65 b-body wiper pivot kit - new - Schumacher
65 b body firewall seals w/o air - left overs
65 reverse light gasket kit - new
65 door handle gaskets
65 tail light gasket kit
corbin hose clamps - left overs
2 exterior rear view mirrors - new
brake pedal assembly - used
2 interior door handles - used - 63-66 A/B/C
2 short (4") interior window cranks - new - 63-66 A/B/C
1 long (6") interior window crank - used
2 black door lock push buttons - new
1 plastic repop heater delete plate - new - needs paint or chrome
65 b body light bulb kit - left overs
1 engine ground cable , about 11" - new
Powermaster alternator - new - PN 74091
727 valve body, stock, installed but never used
body plug kit - left overs
rear window clip kit - 64-65 b body
door window hardware kit - 64-65 b body
bench seat rail mounting spacers - new
rear axle brake line hose tee - used
window crank spacers - new
speedo cable grommet - new
interior door handle rod sleeve
insulated power stud - new
parking brake cable grommet - new
headlight adjuster kit - new
master cylinder nuts - new
motor bracket to block bolts for hemi - used
master cylinder support plate nuts
licence plate fastener kit - new
2 chrome door lock push buttons - new
sill plate screws - 64-74 - new
front shock lower bolts and nuts - 64-69 - new
rear axle vent - used
wiper motor nuts - 64-74 - new
rear window trim hardware - 65
throttle cable
misc. hemi cross ram linkage pieces - not complete kit
green steering wheel - used, no cracks
interior dome light lense and chrome bezel - new repop
carter fuel pump M6903 for BB and hemi - new
chrome thermostat housing - new
fuel pump push rod - new MP P5249569
brake push rod and spring - used
ARP convertor bolts, 240-7301 - new
starter terminal block
torsion bars, CZL778R, CAC779L - used
brake pedal pad - used
wiper switch - used
blower switch - used
window channel felt - new
dash regulator - used
misc. steering column stuff with firewall plate
MP kickdown cable P4510645 - new
MP kickdown bracket P4510319 - new
MP chrome coil bracket P4286728 - new
parking brake pedal pad - new
65 Belvedere gas tank fill tube - used
battery tray - 62-65 b body - new
battery hold down bracket - 66-69 A/B - new
1965 Belvedere instrument cluster - used
