Hi, how do you stretch the headliner on the sides, if you have to tuck it up to grab the teeth on strip that holds the bows ?
Also, where do you apply the glue. Thanks
Stretch the front and rear first. Then on a side pull it to you and with a paint stick or something similar, tuck the material up onto the teeth. Clothes pins or rubber covered spring clamps will help hold it as you move from one side to the other doing a small section at a time.
Thanks Guys, this is the 1,St headliner I've done on a later b body, different with the side teeth strips, done one on my 70 Cuda& 2- Chevelles, which didn't have them, Cheers
