FOUND '66 Belvedere door panel bright work
70Bronco
1:00 AM
Indiana
Looking for the stainless steel trim piece that goes on top of the interior door panel for a 1966 Belvedere II hardtop 2 door. I need the driver side door panel trim--mine is missing--so if you have an incomplete set, but have that one, that would be perfect.
Does a ‘67 Coronet fit a ‘66 Belvedere?
I imagine the panel below the passenger window is the same. I've got one good piece of trim on the passenger side, the other one is broken in half...for reasons unknown. I'll measure the good strip and get back with you with the length and a photo.
The length is 32" but most of it is behind the back seat. took a picture of the broken one as well to see if the cross section is close enough.
Are the back trim pieces around 32"? And what would it take to own them?
What are the dimensions? The front door panel trim is 39.5” long on the front, 37.5” on the backside, and 9/16” wide on the front. They have finished edges front and back. The driver's side front door is the one I really need.
673218A9-2C25-453F-A0E2-C40DA7454A4C.jpeg 4708AF5E-5AE4-48E5-BAD0-A20C63C7E145.jpeg 532FE092-DE67-495A-9428-ADD72A327635.jpeg
Still looking for driver's side door, door panel trim for '66 Belvedere 2 door hardtop.
Anybody have one?
I checked the front piece I have. 39.5 on the chrome. 37.5 on the mounting side.
Still looking for '66 Belvedere 2 door driver's side chrome door panel trim. If anybody has extras, get in touch.
