FOR SALE 66 Bendix Stromberg 2 bbl WWC
Dana67Dart
2:01 AM
Northern Colorado
66 383 from a 66 Furry II
I have not opened it up but I can here the float clank open and shut
The throttle blades are mostly stuck in the open position. They will move a few degrees. I have PB blaster on it right now which has helped.
The throttle lever has a little play
The choke opens and closes freely.
The bowl vent opens and closes freely.
The idle mixture screws move freely
No obvious signs of damage. There is a small vacume tube that is crushed on its end but it comes out of the carb easily
$25.00 plus shipping from 80526
Weighs in at 5 lbs and will need a 10x10x6 box I'll remove the air cleaner bolt for shipment.
If you are serious I'll open it up and send you some photos
I prefer PayPal or Zelle
