66 Charger Quarter window progress.
Terry Kitzman
8:52 PM
S.E. Iowa
I finally got one side window done, When I tried to roll it up it pulled the triple rollers off the track, This happened twice! The third time I tried it pulled the big roller off the upper triple roller. I finally figured I had the upper adjustment on the forward track way to far in. A note the poor souls that have to do this job. Mark your adjusters before you remove them, So you can put them back in the right position !!!!! I just love working on my Charger!!
Glad its working for you.. I have to do mine.. so now its my turn to swear a bit.. :D
Don't crank the window up fast when testing it for adjustment.
Watch things as they move.
Bad things can happen as you found out the hard way.
Your warning probably should be in the sticky thread.
I also kept this sheets of cardboard taped to the windows (inside and out) while making the final adjustments. Note: I didn't have the window fuzzies in yet.
